failed to load bootloader with latest firmware update.
Thanks,
Mel
Live Stream Broadcast
— Broadcast live audio and video from ARC camera to the web via HLS; cross-browser streaming. Requires router configuration for external access.
Thanks,
Mel
I have tried it over and over and over. It connects up. It says ping ping and loading bootloader then, it says "failure to load bootloader."
I have the same problem!
WOW! I haven't said much. But, I am impressed by you Niek. You remind me of myself. I started off with a science laboratory in the 5th grade. Don't let nothing hold you back!!!
Mel
failed firmware update.
Attempting connection to COM40 EZ-B reports EZ-B Firmware V2 Connected Press the UPDATE button to start upgrade Starting Boot Loader...
sending ping sending ping sending bootloader I am EZ-B BootLoader. Gimmie Firmware!
Updating... (21,560 Bytes)
and it's all
above houre ..... happing nothing !
Pls, help
@romango9 reboot? looks like you have a brand new board and your bluetooth module is not working properly. Do you have built in bluetooth, or are you using a usb dongle?
Also, for those updating with this firmware. You have 3-4 seconds after the connection to press the UPDATE button and select YES from the warning dialog. Otherwise, the update will not begin.
It's a new safety precaution to ensure you're paying attention
You can tell if too much time has passed when the status LED of the EZ-B begins to pulsate again. That means you have to restart the firmware update software and cycle the power on the EZ-B
Edit: Got it working... Had to remove the BT connection and add it again after that it worked. But the synapse isn't working yet...
DJ Sures, Hi.
the msg from update console
the leads ( blue and read) are ligthing (no pulsing) - I think it's established connection
progress bar (near update but.) is full
as I understud from U'r tutorial video after msg "Updating... (21,560 Bytes)" must be continue above 5-6 min, but in my case happing nothing
