DJ, Do you have the little 5V fans for sale yet? If not will you soon?
Bookmaker
— Edited
4 Participants
Sketch Pad
— Script-driven Sketch Pad for ARC: draw shapes, text, lines and faces via controlCommand() to visualize object locations, paths and robot data.
I found some on ebay, very cheap. The little fan works great and plugs right onto the board (no mods to the cable needed). But I am looking forward to the servo expansion board DJ mentioned in another post.
here is a link for the fan https://www.ebay.com/itm/1pc-ADDA-Ball-Bearing-MINI-DC-fan-AD0205LB-K50-5V-0-05A-25-x-25-x-6mm-2506-/180776321970?pt=LH_DefaultDomain_0&hash=item2a171bc3b2
Yes, I have seen that also but I would rather suppport DJ and his efforts rather than China. I do appreciate your tip and if DJ says it will be awhile I will probably go with your suggestion.
We're releasing a case with a fan. It will be ready with the launch of EZ-Bits, in about 2 weeks. This Canada Customs mess has rattled us; we're a little behind on everything.
Hello, DJ. In your film Robot Voltage Regulator Fan it is shown, how you connect power supplies to the system block through tiny digital ampere-volt-meter. Tell please how it is called and where he can be bought? Regards, SergeyZN
Bump...on easy bits....anyone......beuller...beuller...
