Hitachi-LG LDS Lidar icon Hitachi-LG LDS Lidar — Hitachi-LG LDS 360-degree LiDAR driver streaming scans into ARC NMS for obstacle detection, SLAM use, Arduino hookup, config options and variables. Try it →
Faster Sonar Ping Interval Possible?
Hello,
I've been working with a few different types of sonar modules, the Parallax Ping, the SRF04 and the SRF05 and in ARC using either the radar scan, distance, or collision detection the "ping" interval can only be set from 100ms all the way up to 60000, is there a way to set it lower to say 20 or even 10?
I also noticed that the distance measurement is off as well, the sensors I have can detect as close as an inch away, but ARC does give an accurate distance. I have changed my wires and tried the sonar that came with the EZ-Robot kit, same issue.
Thank You
The fastest response within ARC is limited to 100ms (which is 10 times per second). This is to avoid flooding the communication channel. If you wish for a faster speed, you can do so with the C#/VB EZ-SDK and create your own application.
Hi Dj!
I've only been using your product for a few days, but I have to say you've got a really good product here, compared to writing code from scratch, I had taken one of my custom robots and replaced the controller (Parallax Propeller) with your controller and had it running in less than 5 minutes! This gives me more time to work on custom built robots instead of playing around for hours programming, so for someone like me who prototypes, this is great!
I'm still trying to figure out the sonar distance measurement problem I am having, where it's 12 inches away from a target, ARC says 18, I did change out the wires and they are less than 8 inches from sonar to controller, this includes the sonar that came with your kit. Is there anything else I can try?
Thank You
The value of the PING sensor is not in inches. This is because every ultrasonic ping sensor returns a different value - so calibration is nearly impossible. The number is simply a unit of imaginary distance for that particular sensor:)
Thank you for the kind words. I appreciate them:) I'm glad to hear we've been successful at providing you with a prototyping platform. I love hearing that!
DJ,
I think I know what the problem may be with the Parallax Ping sensor is, according to the spec sheet for it:
Input trigger: positive TTL pulse, 2 s min, 5 s typ.
Echo pulse: positive TTL pulse, 115 s minimum to 18.5 ms maximum.
So if it takes the EZ-B 100ms to read a responce and the ping sensor is 18.5ms max it's taking too long and the responce is not accurate?
Let me know what you think.
Thanks again
Oops, you posted just before I did, that answers my question then, so basically I just need to find a number that works with the robot the sensor is on for distance, thanks again..
@ charleybot. Pull out a tape measure and make a mark every two centimeters. The get a object that is easy for the sensor to see like a shoe box. Move the box every couple centimeters and write down the value the sensor is registered. This may vary for each sensor so this is good info to have. Then you will know aprox distance in centimeters for a given value the sensor returns. Make sense? To be accurate as possible do this with every sensor and take notes as each sensor may vary 2 to 4 centimeters off from another one. Have fun:) - Josh S.
@charleybot i see what you're asking. The Poll Interval value in ARC doesn't affect how the EZ-B communicates with the sensor. The Poll Interval determines how often to update information from the sensor. If the ARC asks the EZ-B for sensor information too quickly, the communication channel will overload. When that happens, your servos and other things will act strangely and lagging/delayed.
@jstarne1 - Thank you for the idea, actually that was what I was doing today before we got hit by hurricane Sandy, have to finish it tomorrow.
@DJ - I understand what your saying with the issue of data being too fast over Bluetooth, which I was wondering about, I changed out the Bluetooth module with a Roving Networks RN-XV WiFly module (https://www.sparkfun.com/products/11047 ) simply because I have Wifi throughout my house and yard and the host data rate on the WiFly is 464kbps, so far connecting to the EZ-B is much quicker than with the Bluetooth module, but according to the specs for the BC417143 it's data rate can go up to 3Mbps, so I am wondering if there's going to be any issues using the WiFly module?
Thanks again..
