Feature Request - Invert Option On Auto Position Screen
As a newbie I have been playing around with a lot of different frames/actions to get used to the Auto Position control. I kept getting confused on the direction the servo was moving, espicially when SIX was not connected. To make it easier I changed the servo orientation so when I increase the servo value it would always move the servo forward or up, decreasing the value would move it back or down. I found this made it much easier to see what direction things were moving frame to frame.
As a new feature if the frame screen had an option for each servo to invert the direction then the actual orientation could remain the same. I think this could work as a display option only and still save internally the actual degrees for processing.
Anyone else have this problem?
