Filereadall Stops Working
Tested with the last version and the previous version
The following code:
1: ClearVariables()
2: $test1 = FileReadAll("c:\dev\test.txt")
3: FileReadClose("c:\dev\test.txt")
4: Print(Length($test1))
Generates an error:
Quote:
Error on line 4: Missing String Quotes or Invalid Expression at index 0: "hello
the "hello" is inside the file, not in the code.
if the content of the file has a "(" the error is:
Quote:
Error on line 4: Missing ) in Expression
I didn't check other combinations but if there is a RegEx involved,
i'm not a fan of regular expressions, although they are very useful.
oh - reading from a file - yeah. i will have to add a new function. A while ago there was a request to read code from a file with functions. This was implemented a long time ago but a function that reads which doesn't execute the function can be created.
I'll have to create a second version of file commands for that.
