Waveshare Bus Servos icon Waveshare Bus Servos — Control Waveshare servos (TTL/RS485): set position & speed, release torque, read position. RTS option for converters; reverse-engineered protocol. Try it →
Firmware Update Question
i have successfully connected my ez robot via bluetooth. everything checks out fine and the com port is working perfect. Everything is working, yet the firmware update will not recognize the robot. It's very frustrating and I've watched all the tutorials and gone through EVERY discusion. This is the message that shows up. P.S. I've tried it on different computers of different brands and still had the same results.
Firmware Updater Version: 2013.03.09.00 3/11/2013 4:32:27 PM - Begin
Attempting connection on COM4 Connection Failed: System.TimeoutException: The write timed out. at System.IO.Ports.SerialStream.Write(Byte[] array, Int32 offset, Int32 count, Int32 timeout) at System.IO.Ports.SerialPort.Write(Byte[] buffer, Int32 offset, Int32 count) at EZ_B.EZB.Connect(String hostname, String tcpPassword, Int32 baudRate) Disconnected 3/11/2013 4:32:31 PM - Connection attempt error
Available Ports:
  • COM1
  • COM3
  • COM4
Have you selected the correct EZ-B COM port? Use the Help menu option to view the online help and watch a video demonstration.
If you are considering contacting us, ensure you have followed the tutorial first. You may find the tutorial by pressing HELP from the menu. If you still feel necessary to Contact Us or post on the forum, we will require a copy of the debug message by pressing the Edit menu option and pasting the debug window contents to us.
Nearly every issue is resolved by properly following the tutorial and ensuring you have the Microsoft Native Bluetooth Stack. This software is not supported in a Virtual Machine.
Hi All,
I am very new to EZ-robot and I think I am having a similar problem:
(1) I have connected the blue tooth and I see the red and blue lights blinking (2) When I checked the blue to device it said that I am on comm 8 (3) when I run the ezbot calibration I get the following error:
Received: Disconnected Comm Err: Not Connected BbytesToExpect: 0
(4) Any suggestions to what I may be doing wrong or how I should troubleshoot?
Thanks!
I have checked the firmware upgrade as well and this is the message I received. So I don't think it is a firmware issue.
Firmware Updater Version: 2013.03.18.00 20/05/2013 12:02:46 PM - Begin
Attempting connection on COM8 Connected to COM8 at 9600 EZ-B reports EZ-B Firmware V16 Connected Your EZ-B has the latest firmware. There is no need to update. Disconnected
I have noticed that when I load servo-calibrate, I receive this message: Is this what I supposed to see?
Received Disconnected TCP Server stopped TCP Server stopped TCP Server stopped TCP Server stopped TCP Server stopped
Thanks in advance for any advice you anyone is able to provide.
Biometric, that always pops up when I open a project. that really isn't anything.
I can confirm the TCP server stop happens every time for me as well. It's not the root of your problems.
TCP server stopped is correct, unless you have the TCP server running (which it is not by default).
See the other topic for my recommendations.:)
