Poland
Resolved Resolved by chrissi!
Firmware Update Question With Ez-b V4
Firmware Update Question With Ez-B V4
Hi
My problem is related to firmware update (Version 16.6) in my private network connected of course to internet via router. In my home network I have subnet addressed 10.10.10.0. All my devices have ip adresses from this network. I set ez-b in client mode with address 10.10.10.15 - and I can get to ez-b via web browser. When I tried to make a firmware update, I have only one address to choose from drop down list: 192.168.1.1:23 and the com ports - how to change the address to real one from my home subnet. Of course I can reset the ez-b to default settings with proper 192.168.1.1 address, but in this case I will not have the internet access, because this is subnet not addressed in my network. The question is what is the problem and if my pc should have internet access during update?
#33
Does it work if you set the resolution to 320x240?
What are the specifications of your computer? Perhaps we are dealing with a driver hardware issue.
Videos help a lot because it gives me a PoV experience.
We will figure this out:)
connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. --->
i had this thismorning.and i unplug averything from router to wifi hub. waited 5 min and start back plug in one at the time.my internet is, beter then ever.
#35
I saw something like this at the school. It happened when I was trying to get my wall-e setup and I was really close to the back of the cart with a 50 inch tv, DVD player and a power strip plugged in. I assumed it was wifi interference so I moved away from the tv. It worked fine after I moved further away from the tv.
It specifically would lock up when I turned the camera on. Without the camera on, everything was fine. I tried ap mode and client mode. Same results.
It might not be it but It might be worth a shot to try the bot in a different location.
#36
If it isn't interference it could be the pc overloading. Try a different pc just to be sure.
I know that with my V3 I plugged a servo into the gnd port and every time I tried to move the servo ARC would lock up and the Ez-b would short out. Could this be happening in the V4 somewhere?
Inspect everything. open up the v4 and make sure there's no faults or visible shorts. I have a couple what I call "bridges" from the top to the bottom of the board chipped so it might be possible with yours.
Poland
#37
I think that my laptop is strong enough: lenovo z580 Intel i5 2,5Ghz, 8GB RAM, Intel centrino wireless-N 220 and win7 64-bit
And in mode 320x240 the same error:
2014-09-18 19:08 - Attempting connection on 192.168.1.1:23 2014-09-18 19:08 - Connected to 192.168.1.1:23 2014-09-18 19:08 - EZ-B reports EZ-B v4 OS 2014-09-18 19:08 - Welcome to EZ-B v4 Beta! 2014-09-18 19:08 - EZ-B v4 ID: 25-54-0-0-47-255-61-58-58-37-37-37 2014-09-18 19:08 - Connected 2014-09-18 19:08 - Setting battery monitor voltage: 6.6 2014-09-18 19:08 - Setting battery protection: True 2014-09-18 19:08 - Setting i2c rate: 100000 2014-09-18 19:09 - Camera Initialized: EZB://192.168.1.1 @ 320x240 2014-09-18 19:09 - EZ-B v4 Camera Error: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZBv4Video.() 2014-09-18 19:09 - Camera Disabled
Camera is working once for a 5s and once for a 20s
Poland
#38
And fresh
2014-09-18 19:21 - Attempting connection on 192.168.1.1:23 2014-09-18 19:21 - Connected to 192.168.1.1:23 2014-09-18 19:21 - EZ-B reports EZ-B v4 OS 2014-09-18 19:21 - Welcome to EZ-B v4 Beta! 2014-09-18 19:21 - EZ-B v4 ID: 25-54-0-0-47-255-61-58-58-37-37-37 2014-09-18 19:21 - Connected 2014-09-18 19:21 - Setting battery monitor voltage: 6.6 2014-09-18 19:21 - Setting battery protection: True 2014-09-18 19:21 - Setting i2c rate: 100000 2014-09-18 19:21 - Camera Initialized: EZB://192.168.1.1 @ 320x240 2014-09-18 19:21 - EZ-B v4 Camera Error: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZBv4Video.() 2014-09-18 19:21 - Camera Disabled
Poland
#39
I've just made another test with mobile interface and camera of course. On my mobile phone samsung galaxy S advice I have the same issue like on my laptop - after a few sec camera is freezing and the ez-b is hanging
#40
I noticed that the LED on the camera Add-on board has gone out. Does this happen when the camera is plugged in for a while or just when the camera is enabled?
