EZ-B V3 Configuration icon EZ-B V3 Configuration — Manage EZ-B hardware settings: edit Bluetooth name and apply updates to restore altered configurations. Try it →
Great job - however, disable the Glyph option. There is no need for the Glyph option because you are only tracking the specific color using Multi Color.
Also, there is no need to add the code in the Glyph section as well. There is no glyph being used in your camera.
For information on what a glyph is, press the ? button next to the X on the Camera Control. EVery control has a ? next to the X. When you load ARC, there is a message that tells you about the ? button next to the X. Use the ? button next to the X to find more about controls. The ? button is on every control next to the X close
indeed it works also whithout the glyph.
