Camera Overlay icon Camera Overlay — Displays trained object names as overlays on the Camera Device video stream using Camera Device's object-tracking (shows $CameraObjectName). Try it →
All depends on your machine, and what you are printing.
FlashForge, ABS and PLA. I figure most printers would be about the same. I would like to hear what works for you guys. I am thinking anywhere from statues to robot brackets, even EZ-Bits.
Unfortunately all open source 3d printers on the market today are all different. Different sized nozzles, speed of motors, heated bed vs none. You really have to dial in the numbers on each machine. If you buy a kit you can be messing for months before you get one print that works. I suggest a machine that has been built prebuilt and the bed leveled. And profiles for that machine in what ever the software you use to slice and generate the gcode. A lot of options at the moment.
1.75mm filament for a .4mm nozzle. I have a FlashForge Create Dual.
Are you using replicator g or makerware? Have you tried cura?
Page 17 of the pdf has a very good starting point for the profile to get one print off and running. Other user experiences will most likely be on a forum somewhere, that will help you dial in your profile.
Replicator G profile
Hey moviemaker,
You may find the reprap channel on IRC would be a really great resource for you if your getting into printing and need help with settings - plus it's a real time chatroom usually with dozens of people at a time in it. The people that hang out there include many of the people that have designed the various main models of printers so it would be good guidance. As fxrtst says each machine (even of the same type) can have differences and require slightly unique settings.
I just hope that the files actually become available to print the EZ bits as they are once again quiet on that front. It would be actually nice to be able to print something given the main order won't be here for a long time still. It's actually going to still be longer even from this point than they promised at the start of the year when it was all ordered.
Happy printing,
Jay:)
