Feetech Serial Bus Servo icon Feetech Serial Bus Servo — Control Feetech SC serial bus smart servos via EZB UART or PC COM port with ARC virtual ports, speed, position, release, and acceleration. Try it →
Suspect you would need h-bridges for the motors. They don't specify the mperage, so more research needed. Seems awefully expensive for a bot with only 5lbs carrying capacity.
I noticed on the assembly guide that they are using a Sabre-tooth motor controller.
Another good base is Traxxas chassis, good quality, good suspension, etc. and you can find them used on local buy and sells.
