Ohmnilabs Standalone icon Ohmnilabs Standalone — Connects Ohmnilabs Telepresence robot's UP Board COM to ARC, enabling drive and servo control (neck V0) and integration with ARC cameras. Try it →
Frozen Shoulder Servo - What Servo Do I Need
Complete newbie here. I have a JD Humanoid and one of the shoulder servos is not responding. I have tried plugging it into another port with no luck and plugged the other shoulder in to check it was the servo and not the port. I took the body apart and can remove the servo in question but what servo do I need to replace it? Rotation? Lever? it is marked HD rather than HDD. I didn't want to buy a whole new body and would rather just replace the servo. The user guide does not seem to give an answer on it Any help gratefully received
Have checked all those and it doesn't help
You need this: HDD Servo
There’s no user guide to replace that servo, as its not a supported activity. However, it’s not difficult if you keep an eye on the wire layout as you take the body apart.
Be careful of the lipo battery to not short the wires.
As for identifying what parts are in a component, view the appropriate product page and select "CONTENTS AND DIMENSIONS" tab. There are links to every component included in a product, such as the Humanoid Body (includes battery). You will notice 2 x HDD Servo
Have fun:)
