#33
No worries Jeremie. I did think about putting a fan on top of the bucket to force the vapor through the pipe faster (bit like jets), but didn't like the idea of hanging an electric fan over the vapors.
I did have a look about the stuff that's used to make steam for model railways, but apparently it's quite messy stuff and leaves a sticky residue once it settles. I love the video though. That's a really good projection image. (made me jump too, lol). eek Have you got that link for the projection material?
EDIT: Don't worry, I found some.
Clear rear projection film
#34
lol, hopefully it didn't scare you too bad Steve:)
Here's the link: https://atmosfx.com/products/hollusion-projection-material
I'm sure there's probably an equivalent material at my local craft store but I haven't had a chance to look. I'd much rather go the local route as I only need a small piece of material.
#35
Well,, LOL,, I got a gallon of "Smoke Juice" and a smoke machine. It looks like I will fire it up on the weekend and see if I can fill my workshop with magic smoke anyway.. I must warn my wife not to call the fire department..
Ron R
#36
@Jeremie.
Just gone to bed, but having trouble sleeping for some reason?:P
@Ron.
Good luck with the experiment. I'll look forward to hearing/seeing your results.
#37
Hello All, I ran the smoke machine and got way more than I expected. It filled the shop quickly and it drove me out...LOL...
Commercial smoke juice comes in gallons (US) and works by heating a cup then pumping the juice into the cup. Blowing air over it thru a nozzle with holes in it makes the smoke.
You can make a lot of smoke easily, but it may get messy. Combining it with the fan and screen ribbon would look great for the projection.
Ron R
PS there it an odor, not bad, but it has a smell.
#38
Ah man.... you guys are doing it the hard way.... Here's what you do... Just go out and buy a bunch of arduino Uno's and run 24 Volts through them. Reverse the polarity if you're feelin' it:D...... That should provide you with a lot of that magical smoke for your hologram.... :P
#39
Hello my friend,,,, Yes, there are plenty around, and cheap too!
Any thoughts about those VEX motor Servos? or should I add them to the Arduinos?
Ron R
