I ordered a Solidoodle 2 Pro which arrived today. I also ordered with that 2 rolls of filament. It should be 4 total pounds of material to start with.
jstarne1
— Edited
Dual-Axis Compass
— Dual-axis I2C magnetic sensor for EZ-B robots enabling magnetic direction sensing; requires short 2-3 in wiring. Third-party hardware.
@Antron007, I don't own a Maker-bot. I own a Maker-bot clone. It is the same as Maker-bot, but has Way more improvements. I would recommend it to anybody. It is like the Replicator. It prints both ABS and PLA. The Solidoodle seems made better because it is metal.
@moviemaker- Clones are cool. Did you build it or could you tell me what brand it is? I already want to build one but I wanted to own one and get familiar first.
It is called the FlashForge Create, you can read about them here on a USA site instead of having to go the the China web site.
FlashForge 3D printer
@Antron007,
That looks pretty awesome. Still just a little out of reach for me but I'm hoping that the SD2 will keep me busy long enough to save up for one. I might build a 3d printer once I'm more familiar with the mechanics of them. Thanks for all of the great info.
@Josh- I know you've been busy with the truck but, how's things with your printer going?
I turned the printer on today to try and print something small and the Z axis motor that moves the bed won't move...
https://www.youtube.com/watch?v=4lthYHfWYJo&feature=youtube_gdata_player
Sorry about your troubles Josh.... However, this is precisely why I wouldn't invest in new technology until it matures to the point of reliability... I thought about getting one, but unless I spring for the expensive Makerbot I am just going to hold off until reliability catches up with the industry.
Josh have you tried turning the Z shaft by hand and see if you can raise the print plate up ?
