I have checked all of my servo alignments and they all appear to be correct. They all have clear movement and are properly aligned but I notice when the bot walks some of Servos jump and skip movement. They sometimes are not fluid. I have held the bot in my hand and tested the movement and they still skip. Is this normal? Should they always be fluid movement as long as nothing obstructs them? Do I have bad servos?
dodgerrr
can you check your project against the original.to see if you got desame, amount of frames.also you can test frame by frame in auto possition, if he does it.
I just tried to check everything after recharging the bot and I was going to shoot some video of the servos skipping but it seems to run smooth right now. It does it intermittently. I did notice I was close to 7 volts when it was doing it. Could it be low power causing it. Also I am using the Galapagos bot program by DJ.
dodgerrr
when he does averthing right when batt is charged.then the low batt wil be, the cause.did you hear warning sound my batterie is low?
That's what I'm thinking but I need to check it more. Cause I believe the servos skipped on a full charge. I will keep checking the bot
In other words, if it's not the battery what else could cause certain Serbia to skip and not run fluid. It seems like it's two servos in question.
you can try re download new ARC. you can check all wires. check Auto Position frame by frame you can mesure the batt after its fully charge to see its really full.
Sounds like wifi interference. Try changing the ez-b to a new wifi channel.
Was the robot working well before this? Is this a new problem?
If so, have you stopped and started the ARC program? I have had some screwy things happen and was sure I had a bad EZ-B or a bad servo. It would usually happen right after a servo would be blocked from moving properly because the robot fell over in a tight spot. I even tried a different port for the servo and it still wasn't working right. Tried a different servo on the original port and still screwy. Turned the robot on and off, that sort of thing. Nothing worked. Finally I shutdown and restarted the ARC program (as well as cycled the power on the robot) and reconnected to the robot and all was fine.
