Garbage data on EZ-B UART with GPS
Garbage Data On EZ-B UART With GPS
I’m adding a small u-blox NEO-6M GPS module (TTL serial, default 9600 bps) to my EZ-Robot AdventureBot and trying to verify comms with the Serial Terminal skill. If I plug the GPS into a USB-to-TTL dongle on my Windows laptop and use Serial Terminal in PC Terminal mode (COM6, 9600, Flow Control: None), I get clean NMEA sentences every second. But when I move the same GPS over to the EZ-B v4 and switch Serial Terminal to EZ-B Terminal mode (UART on D5 TX / D6 RX, 9600, Flow Control: None), I either see random symbols or nothing at all.
Wiring details: GPS VCC to AdventureBot’s 5V on a digital port, GND to GND, GPS TX to EZ-B RX (D6), GPS RX to EZ-B TX (D5). I also tried powering the GPS from a separate 5V buck with common ground and got the same behavior. I verified baud at 9600, tried 4800/19200 just in case, and toggled the skill’s newline send options. If I keep the motors still, I sometimes see partial readable strings; if I drive the AdventureBot motors, the serial output becomes entirely garbled.
Things I’ve tried/observed:
  • Swapped TX/RX to confirm crossing is correct
  • Shortened the jumper leads and routed them away from the motor wires
  • Added a 100 F cap across GPS VCC/GND at the module
  • Confirmed the GPS talks cleanly via the PC Terminal again
Questions I’m stuck on:
  • Is the EZ-B v4 UART RX pin 5V-tolerant, or do I need a resistor divider/level shifter from a 5V GPS TX?
  • Any Serial Terminal skill settings I’m missing for EZ-B Terminal that affect stability (buffering, timing, CR/LF) when reading continuous streams?
  • Best-practice wiring/power tips on AdventureBot to keep UART clean when the wheels are moving (caps, ferrite, separate 5V regulator, or using 3.3V instead)?
What’s the recommended way to reliably read a 9600 bps TTL GPS on the AdventureBot using the Serial Terminal skill’s EZ-B Terminal mode without getting noise or garbled data when the robot is driving?
Adventurebot by EZ-Robot
AdventureBot with Synthiam ARCx: drive, stream live video, follow faces and colors, use speech, AI, and browser control.
EZB UART parser and Serial-TCP bridge to connect EZ-Robot cameras via Teensy USB, enabling ARC camera control and USB-to-serial bridging.
Serial Terminal by Synthiam
PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex
The behavior you’re seeing usually points to signal integrity/noise, not the Serial Terminal skill itself.
A few important notes for the EZ-B v4 / AdventureBot:
1) UART level compatibility
The EZ-B v4 digital pins are 3.3V logic, so a 5V GPS TX line into EZ-B RX is not recommended.
Even if it sometimes works, it can cause unreliable reads and potential long-term issues.
Best practice:
  • Use a level shifter or at least a resistor divider from GPS TX EZ-B RX
  • GPS RX can usually accept the EZ-B’s 3.3V TX fine, but check the GPS module specs
So yes - for a 5V GPS module, level shifting is the right move.
2) Why it gets worse when the motors move
That’s a classic sign of:
  • motor EMI/noise
  • power rail sag
  • ground bounce
  • long/unshielded UART wiring picking up interference
Even if the GPS works on the PC USB dongle, the AdventureBot environment is noisier when the drive motors are active.
3) Serial Terminal settings
For a continuous GPS stream, there usually aren’t special Serial Terminal settings that "fix" garbling in EZ-B Terminal mode.
Things to verify:
  • UART is initialized at 9600
  • Flow control = None
  • no extra line-ending options are needed for reading NMEA sentences
  • make sure nothing else in ARC is also using that UART
If you want to test the UART directly, a simple ARC script using UART.initHardwareUart() and UART.hardwareUartReadStringAvailable() is often better for debugging than the terminal view.
4) Wiring / power recommendations
For the AdventureBot, I’d suggest:
  • Power the GPS from a clean regulated 5V source
  • Keep a common ground with the EZ-B
  • Add the level shifter/divider on GPS TX
  • Keep UART wires short
  • Route UART wires away from motor wires
  • Add a larger bulk capacitor near the GPS module and/or EZ-B power input
    • 100 F is okay, but I’d also consider 220-470 F
  • If possible, add 0.1 F ceramic decoupling close to the GPS module too
For reliability, I’d do this:
  • GPS TX resistor divider/level shifter EZ-B RX (D6)
  • EZ-B TX (D5) GPS RX if needed
  • Power GPS from regulated 5V
  • Common ground
  • Short twisted pair wiring if possible
  • Keep motor wiring separated
6) Best way to confirm in ARC
Try reading the raw UART data in a small script instead of only the Serial Terminal display.
Example in JavaScript:
UART.initHardwareUart(0, 9600)
while (true) {
  var data = UART.hardwareUartReadStringAvailable(0)
  if (data.length > 0) {
    print(data)
  sleep(100)
If the data is still garbled when the motors run, that further confirms a hardware noise / level issue rather than ARC settings.
Bottom line
Most likely fix:
  1. Do not feed 5V TX directly into EZ-B RX
  2. Use a level shifter or divider
  3. Improve power filtering and wiring layout
  4. Keep UART wires short and away from the motors
If you want, I can help you wire the NEO-6M to the AdventureBot EZ-B v4 pin-by-pin and suggest exact resistor values for a divider.
