EZB Connection icon EZB Connection — Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C. Try it →
Gearbest.com 64 Bit  Mini Pc With Ez-b V4/2
Gearbest.Com 64 Bit Mini Pc With Ez-B V4/2
I am curious if anyone has tried using the EZ-B v4/2 with one of the 64 Bit Windows 10 Mini PC's offered on Gearbest.com. They come equipped with an Intel Atom X5-Z8350 CPU, Bluetooth, WiFi and only need 12 volts DC. I have one with the following specs:
Z83V Mini PC - WINDOWS 10 Model: Z83V Type: TV Box System: Windows 10 Processor: Intel Atom X5-Z8350 CPU: Intel Atom X5-Z8350 Core: 2.0GHz GPU: Intel HD Graphic RAM: 2G RAM RAM Type: DDR3 ROM: 32G ROM Max. Extended Capacity: 128G Decoder Format: H.263,H.264,H.265,HD MPEG4 Video format: AVI,DAT,ISO,MKV,MP4,MPEG,MPEG1,MPEG2,MPEG4,RM,WMV Audio format: AAC,APE,FLAC,MP3,OGG,RM,WMA Photo Format: GIF,JPEG,JPG,PNG Support 5.1 Surround Sound Output: Yes 5G WiFi: Yes Bluetooth: Bluetooth4.0 Power Supply: Charge Adapter Interface: 3.5mm Audio,DC Power Port,HDMI,LAN,Reset Port,SD Card Slot,USB3.0 Language: Multi-language HDMI Version: 1.4 Other Functions: 3D Games,3D Video,Airplay,ISO Files,Miracast,NTSC Power Consumption.: 12W RJ45 Port Speed: 1000M System Bit: 64Bit WiFi Chip: AP6234
-Sean
I just recently bought that exact computer. It works great with ARC.
Oh that is great! I was worried about it only having 2 GB RAM and was wishing I got the unit with 4 GB.
I have an Omnibot 2000 that I want to install it into along with the EZB 4/2.
Alan, if you open the case on the Z83V you will find an hidden USB port! You can add a 128 GB thumb drive or add a stronger / better WiFi adapter.
-Sean
