Brushless Motor Movement Panel icon Brushless Motor Movement Panel — Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement. Try it →
Its a value between 0 and 255. There is no unit because every sensor has a different range. If you want units, you'll need to calibrate and calculate yourself:)
