hi all I am writing my own radar script
how do i use the value return by getping(d13,d12) e.g. :loop tr if getping(d13,d12) < 20 then Right(200) goto(tr) else stop script and exit
Feetech Serial Bus Servo
— Control Feetech SC serial bus smart servos via EZB UART or PC COM port with ARC virtual ports, speed, position, release, and acceleration.
hi DJ it would not do a right()?
Strange. Works in my test when I wrote it.
hi DJ i'll play with the timing of the scan etc.
Okie
Ah you know what? Maybe don't have it move from 10 to 80 because that might be what's happening. Have it move from 10 to 40. The. 40 to 80. Then 80 to 40. Then 40 to 10.
Repeat
Also, if you get the latest ARC... There is a C# example for a radar control. Look under File -> Examples -> Script C Radar Control
hi DJ Thanks i did a little mod
