Community Robot Questions Glyph Detection PRO Herr Ball USA Asked Mar 2013 — Edited Mar 2013 1 Participant Rich Glyph Detection ARC Skip to comments Jump to end Sorry but I believe I found what I'm looking for. I was unable to delete post, only edit it. blush Herr Quote Jump to end Upgrade to ARC Pro ARC Pro is your passport to a world of endless possibilities in robot programming, waiting for you to explore. Compare Pro Features View Subscription Plans Rich United Kingdom #1 Mar 2013 Check in the setting, under scripts there are scripts to run on detection of each of the glyphs. So basically, if it detects Glyph 1 it will run the script set in settings for Glyph 1. This script can be anything. In your case, I assume it would just need to be; MP3TriggerPlayTrack(D0,38400, 1) or PlayAudio(1.mp3) Reply Quote Share Rich United Kingdom #2 Mar 2013 And you found that before I finished replying... it's here for future users to find though. Reply Quote Share Herr Ball PRO USA #3 Mar 2013 Thanks Rich I didn't really see anything on the Glyphs in the manual but looked closer at the QR codes and put 2 and 2 together and there it was Reply Quote Share Login to post a comment
or
Thanks Rich
