Is there a list of Supported Glyphs?
Can I create my own Glyphs?
Auto Position Movement Panel (Gait)
— Create servo frames/actions to animate humanoid, hexapod or custom gaits with smooth transitions, SW ramping and directional control
Howdy
On this page right before the videos start you will see a small link for the glyphs downloads.
https://synthiam.com/Tutorials/Help.aspx?id=80
I believe at this time EZ only supports the 4 in the download. You might want to check out the QR code in EZ too.
Good luck!
I thought you could use custom glyphs as there is an option in Camera settings to select them, however I've not used this feature so I may be wrong... (please correct me if I am)
A direct link to the glyph.pdf is here
That said, as Herr Ball pointed out, look in to QR codes as there is so much more that can be done with these.
Every control has a question mark next to the close X button. Pressing the question mark button will direct you to a tutorial page for the respective control.
Awesome thanks
I will try the custom in addtion.
For my project I am needing more than 4 if possbile
