Miscellaneous Utility Plugin icon Miscellaneous Utility Plugin — ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions. Try it →
Going For A 1/16 Tank Base For Robot - Pro's And Cons ?
After messing around with Servos, Cogs and home made tracks for "Bob" the last 2 weeks I've decided to give in to the idea of a RC 1/16 Tank Base. I was impressed with Dogbots mobility and they seem to have a low centre of gravity and move pretty good outdoors."Bob" weighs about a 1 kilo so I'm guessing it should be able to move him at a reasonable pace.
If anyone has any tips or anything I should watch out for I would greatly appreciate it.
Likewise, I have a 1/16th tank my son wanted to turn into a "Party Bot". So his will mostly be lights and sounds, and maybe tow a little 6-pack cooler/trailer.
Thanks Guys - I'm going the right direction. One thing Edison, the vexrobotics kit Looks great and a very economical option but they want $109.00 just to ship a small box of plastic to Australia - for that I can buy a whole 1/16 Tank.. does anyone know of a distributor with more realistic shipping costs - maybe from the pacific region or similar product ?
The Dogbot Base works pretty good but, like everything else in life it has pros and cons. It was very easy to mod, except for the initial gut reaction to NOT want to destroy a brand new perfectly working cool Airsoft Tank! ? Getting H-Bridges to work was easy at first, but It took me three brands to find the one that could handle the power requirements. I am using the Sabertooth 2x5. Since it's not carrying much weight, it can move really fast, so I have it set at 1/3 the speed. I am hoping I can come up with a way to adjust the speed on the fly, using the joystick. I am teaching myself C# (chapter 3 so far), so it may take a while. There was enough room inside the tank to add 2 battery paks, plus the original battery slot underneath. You could make more room by cutting out the batteries internal storage compartment. The small motors and gears pull a fair amount of torque, but they create a lot of noise. The tank came with metal tracks which work great for outdoor use, but adds to the noise level. I was able to get the tank for 130.00, I looked online or cheaper or comparable robot bases, but anything big enough to carry my anticipated weight, started at 300.00. So I figured this was a better deal. Plus my Son and I got to play with the Tank for a couple of months before I finally decided to cut it up.
Thanks Dave for the Tank tips and Edison for the treads lead. I guess with the treads there is the advantage of customising them with the right motor & h-bridge combination to suit the robot. Again the shipping costs for the treads from robotshop to Australia are more than the cost of the product - I just can't justify that but my friend Richie may have a way around it. There is a similar tread distributor in China and if I get any luck through their emails, the shipping should be much cheaper. From what Dave was saying, plastic treads are preferable to metal {noise, weight etc). Again, thanks guys, I'll get there eventually...cheers
I bought a 1/16 tank on ebay for 45 bucks - radio did not work but who cares. Metal gearbox and plastic treads.
Ecuador
@Hazbot Your welcome!:) and can you give me the link where you bought the tank treads??
