Hi will ARC work under Google Chrome OS? Thanks, Roger
rolew
— Edited
Wheel Encoder Counter
— Arduino UNO wheel encoder: reads left/right ticks, provides counts, configurable ticks, wheel & pivot sizes, optional pose telemetry to ARC NMS.
ARC only works on windows 7/8. If you want to run it on a chromebook, you could try the http server, which would require a windows pc to run the ARC program and host the server. Then you can connect to that server through your chromebook via the web browser.
Thanks so much
No problem!
