HMC5883 Compass icon HMC5883 Compass — Reads HMC5883 3-axis compass via I2C and updates EZ-Script variables on demand; polled control offers periodic heading data, for connected sensors. Try it →
DJ, Do you have any tutorials for using the GPS functions? I have a Bluetooth GPS that works fine on the PC. I can see the GPS data streaming in Hyperterminal. But ARC doesn't show any data. It says it's connected to COM 3, but no data.
Mine is also connected into ARC but I have the same problem with my project. A tutorial would be great. I know someone here has it working
Thanks for the link. Hyperterminal shows the GPS is sending NMEA data streams. Baud Rate defaults to 2400, but I was able to change it to 9600 and still receive the data. It just doesn't show in ARC. I will have more time this weekend to work on it
Well just tried Hyperterminal and it auto detects the GPS data on the bluetooth com port at 2400 8 N 1 and its an RMC sentence type apparently
Hope this helps
Same sentence, different speed.
$GPGSV,3,1,10,22,59,347,,18,57,086,,14,49,313,33,31,31,212,*7B $GPGSV,3,2,10,21,30,175,,25,26,130,,12,21,084,,09,18,037,*73 $GPGSV,3,3,10,27,03,037,,06,00,244,*7E $GPRMC,131429.949,V,,,,,,,020612,,20 $GPGGA,131430.945,,,,,0,00,,,M,0.0,M,,00005A $GPGSA,A,1,,,,,,,,,,,,,,,*1E $GPRMC,131430.945,V,,,,,,,020612,,24 $GPGGA,131431.949,,,,,0,00,,,M,0.0,M,,000057 $GPGSA,A,1,,,,,,,,,,,,,,,*1E $GPRMC,131431.949,V,,,,,,,020612,,29 $GPGGA,131432.949,,,,,0,00,,,M,0.0,M,,000054 $GPGSA,A,1,,,,,,,,,,,,,,,*1E $GPRMC,131432.949,V,,,,,,,020612,,2A $GPGGA,131433.949,,,,,0,00,,,M,0.0,M,,000055 $GPGSA,A,1,,,,,,,,,,,,,,,*1E $GPRMC,131433.949,V,,,,,,,020612,,2B $GPGGA,131434.945,,,,,0,00,,,M,0.0,M,,00005E $GPGSA,A,1,,,,,,,,,,,,,,,*1E
Do you see these sentences on the ARC raw data tab? or is it from Hyperterminal? Whats your actual lat lon location as the line in your data beginning GPRMC should show your Lattitude & Long looks possibly corrupt the data stream needs to be 2400 8 bits No Parity 1 stop bit
I think ARC just looks for the $GPRMC line?? Maybe $GPGGA as well for accuracy information
What was the question?? This is actually really interesting I didn't understand how these things interfaced until I looked into it
No data shows on the Raw data tab. but once in a while when I turn off the GPS I do see information on the Details Tab. The data I have here abd previous were from hyperterminal.
$GPRMC,223658.000,A,2433.5607,N,08145.1343,W,0.00,124.45,020612,,*17 $GPRMC,223657.000,A,2433.5607,N,08145.1343,W,0.00,124.45,020612,,*18 $GPRMC,223656.000,A,2433.5607,N,08145.1343,W,0.00,124.45,020612,,*19
Google Earth and EasyGPS both see the GPS.
Realised the data you had previously was from an unlocked GPS with no signal
Well I couldn't get EasyGps to work or Google Earth with my Bluetooth GPS They wouldn't connect to the correct COM port which was dissapointing. You must have a Garmin or Magellan unit
I downloaded a simple app called GPSutility and that worked with the com port my GPS Bluetooth is connected to and GPSutility set to NMEA protocol. Download this and see if it helps you looks like a non proprietry GPS maybe needed?
