EZB Connections icon EZB Connections — Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices. Try it →
Gps Waypoint Navigation Feature
Hello all, I'm a newbie just join the community. I've started have a look around GPS topic, but I haven't clearly understand if the SDK have embedded functionalities for GPS "mission". My goal is to program a mission (waypoints), send mission to EZ, start remotely the mission and let the rover reach every waypoint in autonomous way. Is this feature available? Are some snippet example/video/other stuff?
Thanks a lot in advance for your hepl! Regs S.
Hi! So first thanks for your kindly reply. @Alan-> in regards the WIFI range you can use a 3G/LTE dongle to expose a WIFI network (to connect the EZ-Robot) and use a VPN to get connected over Internet. This will extend the range until you got 3G/LTE coverage. In regards GPS there's plenty of unexpensive UbloX devices embedding also magnetometer: you don't need movement to get where are you pointing (if you are calibrated of course).
@Dj-> I was looking for something integrated like a "mission planner" stuff inside a simple EIDE like ARC cause my potential end-user needs something really simple. To execute a mission waypoint plan on compatible deviced, normally I use MavLink protocol.
Thanks again. Ciao S.
@Simon_freeman,
It is really pretty simple to do the portion of path planning. For example, I have a product that gets the walking directions from Google Maps from your current location to another location (address that has been geocoded). These points are stored in a table. This table is used to identify what the current destination point in gps coords. There is a function that I have that will tell the robot which degree heading it should be going by taking the current location and calculating the direction it should head to get to the next point. This calculation happens once a second and is returned back to the robot, allowing the robot the ability to modify its route to get around obstacles and then get a good direction to head in again. When the robot gets close to the current destination point, the app marks this point as completed and then loads the next point as the destination location, which then calculates the direction the robot should be heading. This repeats until the robot has reached its final destination. This is all done using C# and the EZ-SDK.
Here are the issues you will face... The outside environment is not a flat or level place void of obstacles. Your sensors for detecting these obstacles are different than other peoples sensors. Your motors and motor drivers are different also. The diameter of your wheels and height of your robot has an affect on what you would deem easy to overcome vs someone else. If you use roads and sidewalks, that becomes easier but then you have to take into account people and vehicles. along with curbs and ramps to go across streets. If it is a field, the height of the grass that day may affect things, and you have to account for people, animals, fences and other things possibly. All of this programming is unique to your setup and the reason that there isn't a module that you can just drop in place.
For my solution, the mission planner is done through voice by saying which location you want to visit that is found on Yelp. From there, Google Maps is used to get the path to the location which is stored locally in a table. This is a solution that is very easy to use from an end user perspective. The rest of the stuff (actually getting to your destination and avoiding obstacles) is the part that each robot would have to be programmed differently on.
Simon, do you have much programming experience? The open plugin architecture will allow you to build a plugin for your needs. Otherwise, maybe sweet talk someone in the community to see if they will help you create one built with a google maps api backend:)
Wouldn't be too challenging - specifically if you have the requirements already outlined.
Hello all,
I'm new this community. I have the six hexapod and want to make him move to a bunch of GPS locations. I have a GPS module attached that works and gives me latitude and longitude. I have problem using the GPSStop command. I want to make the robot go to 5 different locations using the GPS and perform a task at each location. thanks in advance.
Can't answer your question but .... Are you using this outside? GPS is only accurate to about 10ft so sending your robot to waypoints locations indoors would not work very well at all...
How are you controlling the GPS at all? The GPS object was removed from ARC several releases ago. It looks like DJ missed deleting the GPSStop script command when he did that.
Thank you @Richard R, I have been using it outside, it is just a proof of concept I do not want precision. Thank you @Alan, I found a GPS plugin which I used and connected an independent GPS module, I obtained values. Hence I wanted to use this in a program to show waypoint control. Yes, the script help did not have the GPSStop function.
Omg so I cannot use GPS with the hexapod. What are my other options to make this happen.
#16
Oh, I missed that there is a plug-in. If you have lat and lon in variables, than you can write scripts that wait for specific values, or better ranges of values, and then take action (stop, change direction, etc...). A little more complex than the old gpsstop() command, but shouldn't be too hard.
