Neopixel Ring icon Neopixel Ring — ARC UI for onboard computers to control NeoPixel rings via serial: test/run patterns, preview and copy Arduino serial commands, includes sample code. Try it →
#17
Quote:
you can feel it to.the parts are cold
So true...never thought about it, but so true!
hi mickey yes indd cold i did some cheking on the motip colors.they have a lot of color,also, with glinters in and dry in 10 minites.my next wil be in gold color.
here the blue/white adventurebot
hi justin
yes it does.especially with the white color.
here is the gold color from motip.also dry in 10 minutes.
i also notest some diff in the screws from the feet of jd. they are smaller heads of the screws.
one golden ezbv4 and base
here he is the golden jd with backpack.dj can you upload a pic from the primer you used.just incase ,its good to prime the 3d print parts.
also here i notest the screws in feets are totally screwed in the hole.easy fix do.
