The red light is on but the green light is not when I connect to the charger to the roli battery, but when I turn the robot on it says its battery is low.
joshuabkessler
— Edited
EZ-Script Console
— Real-time EZ-Script console for ARC: enter and execute single-line commands, view output, clear display, and recall history with UP/DOWN.
It was the charger.
just got new battery and remote control for my 1984 omnibot robot, should the green light come on charger right away, does it take 12 to 14 hours to see it respond, also remote control does not work right away.
always wait about 10 min after using a robot for charging. same when batt is fully charged wait about 10 min before using the robot. if you charge direct after you use the robot,the green led will not lid up.
many batts charging the first time takes 10 to 12 houres
What battery and what charger are you using? Different chargers are for specific batteries. And each charger will have a different number of lights that mean different things
