Pandorabots icon Pandorabots — Connects ARC to Pandorabots for AI chat, sends text and gets replies (executes [EZ-Script]), integrates with speech recognition and custom bots Try it →
Gripper Stall Detection
I'm looking for a method to stop the gripper servo when holding an object.
I tried a few options:
  1. Servo potentiometer analog read
The values are noisy, and needs constant calibration, requires short delays between the readings (flood issue?)
  1. Force sensor analog read (picture)
The values are noisy and depends on the touching surface.
  1. Tactile button/pad digital read (picture)
similar to a bumper switch (picture) seems more simple to detect (digital signal) but so far nothing small to fit the gripper.
Any suggestions ?
@ptp - you could see if a SynTouch (BioTac) sensor would work for your application.
@69developer:
Nice tech... i can't see the price neither the availability it must be expensive...
You might consider these:
Precision Coil
for sensing the current going through a wire. If motor stalls current will be high, so define a treshold and that might work.
Good luck,
Greetz
