Avatar JD icon Avatar JD — 3D Avatar JD simulator with bidirectional servo sync, action sequencing, $SIM_ scripting, EZ-B emulator support and pose/movement visualization Try it →
Yes. I dont have one, but I would believe that this would be right based on what is available for sale in the store.
got error in line 11 cant find loop?
nomad TMBS , you are very close , yes use the MPU9150, but first add an MPU9150 control to your project. Then look at the variables in the MPU9150, they are not the same as the MPU6050. Try this,
ControlCommand("MPU9150", Init)
sleep(100)
:loop
ControlCommand("MPU9150", RunOnce)
$initheading=round($CompassHeading,0)
print($initHeading)
print("AccelX AccelY AccelZ CompassHeading") print($accelx + " " + $accely + " " + $accelz + " " + $initheading)
print("CompassX CompassY CompassZ") print($compassx + " " + $compassy + " " + $compassz)
print("GyroX GyroY GyroZ") print($gyrox + " " + $gyroy + " " + $gyroz)
sleep(1000)
goto(loop)
Nomad will post the working script. For some reason, the variables were not recognized in the script (even using the correct names). We had to assign new variables and then assign these variables the values from the AccelX and AccelY variables and then use the new variables in place of these in the script. He will post it and you will see what I am talking about. Weird.
#15
from what I remember, this script worked but I am not connected to his computer to see anymore.
sleep(100)
:loop
#Added these because $AccelX and $AccelY were not recognized later in the script for some reason.
$XAccel = $AccelX
$YAccel = $AccelY
IF ($AutoPositionStatus = true)
  print("AutoPositioner already running...")
  sleep(2000)
  goto(loop)
ENDIF
print ("x: " + $XAccel)
print ("y: " + $YAccel)
IF ($YAccel > 8000)
  print("Getting up from front")
  ControlCommand("Auto Position", AutoPositionAction, "Getup")
  waitfor($AutoPositionStatus = false)
ELSEIF ($YAccel < -8000)
  print("Getting up from rear")
  ControlCommand("Auto Position", AutoPositionAction, "stand from sit")
ENDIF
sleep(1000)
goto(loop)
here's the script for the gyro
ControlCommand("MPU9150",init)
sleep(100)
:loop
print("start of loop")
$XAccel=$AccelX
$Yccel=$AccelY
if ($Autopositionstatus=true)
print("Atopositioner alredy running")
sleep(2000)
goto(loop)
endif
ControlCommand("MPU9150",RunOnce)
$XAccel=$AccelX
$YAccel=$AccelY
print ("X:"+$XAccel)
print ("Y:"+$YAccel)
if ($YAccel > 8000)
Print ("Getting up from front")
ControlCommand("auto position",autopositionAction,"get up")
Waitfor($Autopositionstatus=false)
$XAccel=$AccelX
$YAccel=$AccelY
print ("Y:"+YAccel)
elseif ($YAccel<-8000)
print ( Getting up from rear")
ControlCommand (Auto position",AutopositionAction,"stand from sit")
$XAccel=$AccelX
$YAccel=$AccelY
endif
sleep(500)
$XAccel=$AccelX
$YAccel=$AccelY
print ( End of loop...restarting")
goto(loop)
