Slide Script icon Slide Script — Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press. Try it →
Gyro-Sensor Compatibility For Ez-Robot?
Recently as part of my humanoid robot project, I want to use some gyro sensors to balance the robot's body.Is it possible to use a program within the EZ-Robot software so I can use them besides accelerometers and such?
@RoboticsMaster I apologize that no one responded to you last year, that's our bad. @hoolagen1 Thanks for bumping it!:)
Most Gyro sensors these days communicate via I2C and while there isn't an officially supported module you can still add your own using the ARC I2C commands. I would recommend using a 5V based gyro but if you can't find one you could snip off the two 4.7Kohm I2C pullup resistors on the EZ-Bv3 and use a 3.3V based one (that has pullups on the 3.3V side).
Hey thanks man.
I just started getting into a Darwin-op. And a gyro is necessary.
Thanks again.
