Ultrasonic Distance icon Ultrasonic Distance — Displays HC-SR04 ultrasonic distance readings in ARC; scriptable via GetPing(), pausable, sets a variable with multiplier, optional NMS output Try it →
Hello to all and Happy New Year. I am having an issue. When I turn on my H Bridge it not only runs the motor it is supposed to but it also runs a modified servo that is not connected. If I change ports for the H Bridge control it changes the modified servo that it also controls (sometimes). Is there a solution such as a draw down resister on the modified servo ports? Any help would be greatly appreciated.
DJ, Can you chime in on this issue. Why would the modified servo activate when an H Bridge is activated?
Can you provide more detail? Are the hbridge and servo plugs against each other? Maybe its picking up noise? Are you certain there is control that is using the Modified servo port? Maybe a Radar Control or something, with the port set.
I am using two modified servos but not as drive motors. I have tried moving the H Bridge port and it starts the other modified servo. I swiched out the modified servo ports and I still get one of them moving when I turn the H Bridge on. Very strange.
I am running the TB6612FNG. I think I will try capicator on the motor. That sounds like it just might do it. I will let you know. Thanks for the prompt responce and great advise.
I just took a look and found a couple of 103 ceramic disc capacitors that I think are about .01 uf. Do you think that should do it?
only one way to find out
Hi Bookmaker, did you try the capacitors out, did it help? I have some weird problem of my own with this Hbridge, I posted it over in the main topic for it if you are interested. Maybe you have the solution I'm looking for:)
