Graphy icon Graphy — Plot live data with ControlCommand scripts: multi-series charts, many chart types, legend toggle, add/remove series, export graph data to CSV Try it →
H Bridge Question:
I finally had a chance to get back to my robots. I wired up the Motor driver ( per the very through tutorial) and hooked it up to the EZ-B as follows: AIN1 to D15 AIN2 to D16 BIN1 to D17 BIN2 to D18
Left Trigger A assigned to D17 Left Trigger B assigned to D18 Right Trigger B assigned to D16 Right Trigger A assigned to D15
VM connected to seperate battery pack (7.2 volts) positive
Connected the EZ-B Opened an H-Bridge movement panel..................then clicked on all 4 directions and...............................Nothing happened !!!!!! Where did I go wrong???????? What am I missing? Thanks all
Great work. you've connected 4 of the wires as a start. What about the others?
Did you connect the pwm and other wires? Look at the tutorial page, there are many pictures and explanations.
YES! All the other wires are also connected as per your great wiring tutorial for the H-Bridge hook up. I'm sure I must be missing something obvious. I triple checked myself and went through the wiring for the H-Bridge very carefully. I don't have the Neg (gnd) from the seperate battery pack connected to the EZ-B. Would that result in a no go?
what do you mean seperate battery pack?
post a pic of what you have
I thought I resolved my problem. I was attemping to connect VM to an entirely seperate battery pack. I think I misconstrued the "connect VM directly to the positive of the battery pack". So, I connected VM to the positive of the battery pack that powers the EZ-B. I then connected to the EZ-B again and tried the movement panel. Still nothing! The "other battery pack" was a 7.2 volt; so I don't think it harmed the H-Bridge.The motors should operate from the Movement Panel just by clicking on the directional tabs, right? They did turn green, but no motor movement! Any ideas?
Picture please. Even a diagram anything at all will help
Do you have one battery powering the EZ-B and a separate battery powering the H-Bridge? If so, I believe the solution is to connect the two negative wires together.
A seperate battery pack was my first mistake. I misunderstood. VM is now directly connected to the positive side of the battery pack that is powering the EZ-B. However; I still have no motor power. I will try to get you a pic tomorrow DJ.
Please a pic or a drawing.
Your GND's will need to be connected:)
