Script icon Script — Multi-language ARC Script: build, run and debug Blockly, JavaScript, EZ-Script or Python with Intellisense, run/save/load and Roboscratch support Try it →
Germany
Google+ YouTube
H-Bridge Question With Ez-B V4
Hello EZ-Robot Team, i have follow problem: I have a remodeled Omnibot 2000 I have successfully operated with the ECB-V3 and the H-bridge. Now I have changed to the EZ-B V4 and since then he moves only very slowly. When I use the PWM controller to Max. Point moves the robot extremely slow. I place the PWM regulator to slowly he drives no longer. Where is the problem? What can i Do?
Please help me!
Thanks an Greetings from Germany Sven
Sounds like the HBridge is wired incorrectly. What you should do is check the wiring. Also, what HBridge are you using? Due to the very slow speed, i am concerned that the motors are wired incorrectly and getting their power from the EZ-B and not the battery. That will damage the EZ-B.
Please provide more information. Such as what hbridge, the wiring and project details.
Germany
Google+ YouTube
Thanks for the quick reply, I am using this H-bridge: https://www.ez-robot.com/Shop/AccessoriesDetails.aspx?prevCat=9&productNumber=14 The wiring has not changed, I have indeed changed for V4 only by the Governing V3. Even the ports I have transferred 1: 1. But I'll check the wiring again, not that I have demolished a cable during the conversion and the H-bridge but now brings the power of the ECB. I will provide feedback after the test.
Germany
Google+ YouTube
Hello DJ, They had the right guess, I actually got a cable from the power supply of the H Bridge demolished. Now everything works fine. Many thanks
