Kinect Body Control icon Kinect Body Control — Control robot servos with Microsoft Xbox 360 Kinect body tracking; map joints to upper/lower body servos with smoothing and pause control. Try it →
HC-SR04 Ping Sensor
HC-SR04 Ping Sensor
This tutorial demonstrates how to wire a HC-SR04 Ping Sensor to the EZ-B for use with the SDK or ARC software.
This sensor is very affordable compared to the Sharp IR Distance Sensor. They are going for around $14 USD shipped off ebay.
Ebay Link
Gnd = black Pos = red Signa = white (or sometimes yellow)
For this sensor, you will need 2 servo cables. One set of wires on the cable will be used for Positive, Gnd and Trigger. Only the Signal wire will be used on the second cable to connect to Echo.
The Gnd and Pos on the second cable can be cut because they will not be used.
I couldn't find the HC-SR04 sensor readily available in the UK so I used the SRF04 by Devantech available from the excellent Active Robot Site
It has 5 connections 1 of which is not used and seems to work just as well:)
That's super! Thanx for the info:D
For some reason, the IC chip on the T side of my HC-SR04 gets REALLY hot very quickly. Any thoughts on what might be causing this?
Netherlands
Check if it's connected to your EZ-B correctly, the last time I had that I had them connected the wrong way and the mysterious blue smoke came out.
(wrong way = signalwire (the white/yellow one) facing the inside of the EZ-B)
I've confirmed that everything is wired up properly. The Ping Sensor control panel was working fine for a few minutes. Then it shot up to 255 and the IC chip started heating up again. The settings are on 250ms interval. Anyone else experiencing this?
Hey guys, I need assistance with my ultrasonic (HC-SR04) distance sensor. I never was able to have it work properly. I have watch the tutorial over and over, check my wiring over and over and it simply refuse to behave properly. I order a new set of 5, coming all the way from China, playing the waiting game. Is it possible that I may have short circuit the ultrasonic board by mistake ?
According to your diagram you look like you are using D8 for the Trigger signal and D9 for the Echo
Yet the notepad says D4 for the trigger and no port for the echo?
Sorry didnt see that D5 for the echo
Diagram is simply for show and tell was easier to draw D8 and D9. I am using D4,5
