Synbot Plugin icon Synbot Plugin — Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support. Try it →
Halloween Is Coming Soon
Hello To All,
This time of year my old plc controllers and arduino ends up at my friends Halloween Barn. I program a number of displays for our friends, both fiends and ghouls amusement.
This year my poor robots will become brainless for a while and two of my ezbv4's will become an addition to the party. One may run a talking head with facial tracking.
I was wondering if the object tracking mode works with an IR camera hooked to my computer? I would like to use my second ezb to run servos and a couple relays using object location and tracking (people) in the dark.
Any experiences or ideas?
Ron R
Yes, any camera recognized by windows should be able to work in ARC.
I hope it works. I assume I will have to set the contrast settings full to make it track. I will post my tests.
Hello to All,
My Madame Ninndo, the fortune teller is progressing well. I will post pictures soon.
I have built a number of Auto Position actions. I listed them in the script manager. I can run each of them by clicking the corresponding start button in the manager. Works well !
I want to activate the action by pressing a push button. Upon completion I also want to have the next action to be ready to run. Sort of like a sequencer. (FIFO) Upon the pressing of the button again, the next action will run, and upon completion advance to ready the next one. Can someone help?
I planned on using a standard push button on a digital input to be the signal. Do I need to build an anti-bounce circuit?
My scripting skills are minimal, but I want to learn.
Thanks,
Ron R
Monitor the digital port with the push button on it. If it's on D0 for example
WaitUntil(d0 = true)
NB: I haven't used EZ-Script for over 6 months so my commands may be rusty, I'm unable to find the EZ-Script manual online so can't confirm WaitUntil() is a valid command or the syntax is correct.
Have a counter which increments so you can cycle through actions.
$counter = 0
Increment it each time the button is pushed
$counter++
Run the required script dependant on the counter
IF($counter = 1)
  ControlCommand...
ElseIF($counter = 2)
  ControlCommand...
Build in some kind of loop to avoid the counter going over the number of actions at the end of the if nest
ElseIF($counter > 10)
  $counter = 0
EndIF
Thanks Rich, I will give it a try.
Ron R
Hi Rich,
I wasn't able to get the script you gave me to work. I understand how it flows but must be missing something. I am trying to get some thing easy to work to learn the basics, but I am missing something.
I tried the following to confirm the input script is ok, but it doesn't work. I must not have the right code.
If (d0= true)
Sleep(500)
Say ("EZB is on") Sleep (500)
Endif
)I also tried it without the Sleep commands)
I tried WaitUntil (d0=true) but no good.
I put a digital read block to see if the input works and it does.
Do you know of any working examples anywhere ? The sequencer is the last part needed for this project, and I want to get it working by Wednesday.
Thanks
Ron R
Ron you should use the UBB code when posting things like code snippets... Try this... It waits for a digital change then executes the "if" condition...
:top
# Digital_Wait(D0, ON, 50) waits 50ms for digital change
WaitForChange(GetDigital(D0))
If(GetDigital(D0)=1) #true
Sleep(500)
Say ("EZB is on")
Sleep (500)
else #false
#do something else
endif
goto(top)
Hello Richard R,
Thanks, I will try the code.
My next step is a sequencer. This script is just to check to be sure the input works and doesn't bounce thus skipping steps.
Ron R
