DHT11 Temp & Humidity Sensor icon DHT11 Temp & Humidity Sensor — Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables. Try it →
Hasbro R2d2 Hack
Hasbro R2d2 Hack
Hello EZ-Robot community!
DJ Sures,
Have you finished the video tutorial for the Hasbro R2D2 EZ-Robot conversion? I just ordered your kit and plan on doing the exact same thing and was looking for ideas, opinions or how-to's considering you have already been through it.
Thanks in advance for any info you can provide!
Doc Seuss
Hi, any update on the video? I've been looking for it, but I'm guessing it isn't posted yet?
What's the delay, are you busy trying to run a business? :)
Hey All!
Finally got some time out in the garage. Sorry that thing called "Life" got in the way! ;-)
Some pics. (Sorry I didn't have my fancy camera with me)
Hasbro R2 in bits and pieces
A close-up of my dome posts. This is how it is on my full size R2. Simply friction fits down on the (4) screw posts.
L298 Motor Controller. Seemed like a perfect fit to mount on R2's center foot.
Another view of R2 gutted.
Back half of R2's body. I utilized the existing mounting posts and added a styrene plate for mounting stuff.
A good view of the rear half of R2. I did some extensive dremeling and removed the whole battery compartment.
Here we have everything fitted back together. EZ-B board mounted.
Gutted dome. Note the black tipped posts. Those match my screws for the friction fit.
Little buddy all back together.
Heart beat...
Another view of his almost complete internals.
12V Lipo 1500mAH battery I've been experimenting with. Fit's in R2 and Wall-E easily. Doesn't seem to run the EZ-B very hot at all.
Things left to do to R2:
  • Add Scorpion Mini speed control for dome rotation
  • Add serial MP3 card w/amp
  • Add Camera to dome eye
  • Add slip-ring to dome
  • Locate and mount Sonar
Hope these pics help other builders with ideas.
Cheers!
Lumpy
