Servo Pad icon Servo Pad — Drag mouse or finger as a virtual joystick to control pan/tilt x- and y-axis servos with configurable ports, limits, inversion, and backgrounds. Try it →
Having Questions Connecting ARC To Wifi
I can get the controller to connect to the wireless router but I can't seem to get ARC to connect to the controller. I get the following error report.
Attempting connection on 192.168.1.1:23 Connection Failed: System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 192.168.1.1:23 at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.Sockets.TcpClient.EndConnect(IAsyncResult asyncResult) at EZ_B.EZB.Connect(String hostname, Int32 baudRate) Disconnected
Have you reviewed the connection tutorial that is presented to you in the form of a question when the connection cannot be established? Give it a quick look and answer the questions - that gives us information to help you.
You are connecing to your router, not the EZ-B. In client mode, your EZ-B will be assigned a different ip address than the default 192.168.1.1. There is a search tool in ARC, or it may be faster to log onto the router to see what address was assigned. Just type it in over the default ( and add the :23 to the end, but not for the camera if you have one).
Check the WiFi modes tutorial in the learn section for more details
https://synthiam.com/Tutorials/Lesson/15?courseId=5 Alan
