whats the best method to use for running from ez? not sure any help would be appreciated, thanks
possum
— Edited
Joystick (Direct Input)
— DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback.
I have two of them on my bot. You have to use one D point each. If you look at my project under the project show case Unfinished, Experiment 626,you can see the two units. Some have said to run with out the jumpers but I run mine just fine with them in.. you need to use a modified servo panel to move them.
