hi all I have wired my motor up HBridge Motor Control. as per the post in
post #2 and it works ok my question is how do i now control it using a joystick?
Set Digital
— Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only.
Hi Baloo, I have my robot B.O.B. controlled via joystick. When you use the joystick control in ARC you assign the Movement Panel and it just works! I love it.
@bret.tallent "it just works" ... now i feel like apple
Well I now have my chassis, it's the track base from a 1:16 scale Tiger tank Using DJ 4 wire HBridge Motor Control see:Post #2
As the HBridge Motor Control has a switch for internal or external +5V for EA and EB , I used the external +5V from the PWM , but find that the motors stalls when the speed is set to less the 30%, so I'll leave it to at 50% min. The power off/on switch under the chassis will later be moved to the back panel of the chassis. The joystick is now working
Now to add the radar
I've tried hooking up and controlling my bot with a joystick controller. Does not work. I am using the L289N dual motor driver ( that I finally got to work) with the 4 wire movement panel. When I open the joystick config window I see that the buttons work but the joysticks do not. DJ's tutorial video says that the (Upper) joystick#1 should control what ever Movement Panel is open. I'm using the "wired" joystick BTW. So, is it me, or are the robot gods just singling me out for punishment?
