Camera Snapshot icon Camera Snapshot — Save camera snapshots to 'My Robot Pictures' (Pictures folder), manual or timed (0-100s), and trigger programmatically via controlCommand. Try it →
Hbridge PWM Only Working On Board 0.
I am not sure whats wrong.  But I've noticed that PWM controls are not working correctly, they sometimes loose connection with the port.  Also I cant seem to get the Hbridge with PWM to work on any board except 0.   Has anyone else had the same issue?
Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning.
I've looked through the tutorials, it used to work as described but not anymore.
Have you checked all your connections and wire? Also post your script so we can see your coding for the second ezb issue.
