Hitachi-LG LDS Lidar icon Hitachi-LG LDS Lidar — Hitachi-LG LDS 360-degree LiDAR driver streaming scans into ARC NMS for obstacle detection, SLAM use, Arduino hookup, config options and variables. Try it →
How are you providing power ?
Check it's wired correctly. Check the power to it is 5V (or less). Check the config of the control is set correctly.
Can you take a picture of your wiring to the ezb board? Check and see if you have it wired correctly...
*** Important do you have the inline voltage regulator installed?***
  1. Power = Red pin D0 (voltage reg'd to +5V)
  2. Ground = Black Pin D0
  3. Trigger = D0 (white pin)
  4. Echo = D1 (white pin)
In the second picture you have the ports reversed from the first picture (trigger and echo)... how about your wiring..? Is it connected to the EZB like my example above? (see post #4)
I think I have the wiring correct, posted a close up photo
