Omron HVC-P2 icon Omron HVC-P2 — Omron HVC-P/HVC-P2 ARC plugin: Python-based camera integration for body, hand and face detection, gaze, age/gender, expressions and face recognition. Try it →
It needs a voltage regulator. The HC-SR04 requires +5V, anything more will damage it.
Any 5V sensor you plug into the V4 board will need a voltage regulator unless you are powering the V4 with 5v (which you probably wouldn't be)... So the quick answer is yes you need a 5V regulator....
That's weird ...not sure if it is just me, but posts 1# and #2 in this thread have been reversed.... Rich's reply is post #1....
Gibraltar
Thanks good info. I think Rick must be psychic
The forum time went a little funny earlier which has made forum post go in a funny order in some cases. I'm good but I'm not that good:)
@Rich... You have invented time travel, haven't you? .... I knew it...:P
Rich is messing with his ezb metaphysical psychic reader adviser program. It looks like it's working great.
OK you got me, I was testing out my design for the new EZ-Bit flux capacitor and accidental use them with the Dagu 4Channel Motor Controller and this example
:D
