Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
Hello Mark,
You can use strips instead but you'll have to change the amount of LEDs specified in the code (I believe you just have to simply change a variable). You'll also have to match the code with the LEDs you are using as there are now quite a few different types of "addressable" LEDs.
