EZB Connections icon EZB Connections — Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices. Try it →
Help Losing Audio With Speech Recognition
I am having audio problems. When I talk to my robot it recognizes commands ,but after issuing about 5 or 6 verbal commands the audio is no longer there. I have the latest version of ARC. Everything else works. Their is also no audio from speech synthesis..No errors are showing .
the robot likes higher voices that i found out. And what is happening to you happen to me I reset my robot and it worked for me. If it dose not work I would make a new file for the robot. Hoped I helped
