Read Digital icon Read Digital — Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval. Try it →
Hong Kong
Help: Need Assistance In Programming 2Xbrookstone Rovers And 2Xparrots
For the awsome office application. Could not manage on my own.
For a fee of cause.
I want them to move around, greet people, recognize movements etc.
Read all of the tutorials and watch the videos. ARC makes it easy for everyone to "program" their robots. If there are any specific controls or functions that you need help with the answers are often in these forums, otherwise just ask.
Hong Kong
I've spent 2 nights trying to program using ARC without any particular success. I believe someone more proficient in this could do this in a couple of hours. Considering above I gave up and would rather pay someone who can do that properly and quick when spend undefined time period trying to accomplish it myself:)
@MCHK, you can watch the tutorial video for the AR Parrot Drone. Press the ? button on the AR Parrot Drone control, or visit the tutorial page: https://synthiam.com/Tutorials/Help.aspx?id=160
You do not need to "program" the AR Parrot Drone.
  1. Load ARC
  2. Connect to AR Parrot Drone over WIFI
  3. Click Add Control
  4. Select Robots
  5. Select AR Parrot Drone Movement Panel
  6. Click Add Control
  7. Select Camera
  8. Select Camera Control
  9. Press CONNECT on AR Parrot Drone Movement Panel
  10. Select AR PArrot Drone on Camera Control Device List
You may now use the buttons on the Movement Panel to control the drone. If you wish to use a joystick to fly the drone, add the joystick control.
  1. Click Add Control
  2. Select Misc
  3. Select Joystick
  4. Press Configure on Joystick
  5. Ensure the checkbox is CHECKED on the first tab "use movement controls"
  6. Switch to second tab (Joystick #2)
  7. Ensure the checkbox is checked "use pitch/roll drone movements"
  8. Press SAVE
Now you may use the Joystick to control the drone
If you wish your drone to follow a color...
  1. Press Config on camera control
  2. select Enable Movement Tracking
  3. Press Save
  4. select "Tracking" tab on the camera control
  5. select the Color checkbox
Now your robot will default track the color red. You can change the color and brightness by selecting the Color tab on the Camera Control.
You can also perform the same to track faces, but select Face instead of Color.
Doesn't get any easier than that:) No programming required.
Hong Kong
Thanks a lot DJ! What a great community here!
Well, so far I've got. For some reason the EX Builder does not like the Parrot Drone's video (no video here). Besides, isn't it supposed to follow movement?
Are you using a AR Parrot Drone version 1 or version 2?
Hong Kong
Version 2
That would be the issue. There is no support for version 2. When you Add the control, in specifies version 1 in the title name:)
Hong Kong
Okay... should Rover track moving object?
