Movement Script icon Movement Script — Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ). Try it →
Germany
I could not find instructions about entering contributions, no Help button, F1 doesn't work, and I also couldn't find a tutorial. Do I have to change my browser settings for display/access to such items? How can I e.g. quote text from another entry?
You put a [q] in square brackets at the beginning of the quote and then /q in square brackets at the end of a quote... Same for [b] for bold and [i] for italic...
On the right of the reply box is the standard UBB code which can be used.
Germany
Looks like I expected too much from a modern BBS :-( Thanks anyway :-)
