Singapore
Help Prevent Jf Faceplanting
Hi all,
When my JD decides that his battery level is low, he lurches forward from a standing position and does a spectacular faceplant on my desk or floor!
To prevent the poor guy cracking his face, I was hoping to script an early warning system that would advise me when he was approaching critical level so I could at least lay him down flat first.
If I recall correctly, the battery warning cuts in at around 6.6 volts so I wrote this small code snippet which runs after connection to alert me when the voltage dipped below 7 volts.
:loop
$batteryLevel=GetVoltage()
if ($batteryLevel < 7)
ControlCommand("Soundboard v4", Track_12)
endif
sleep( 60000 )
Goto (loop)
Track 12 is an audio file that advises 'Energy Cell Exhausted' (I know many of you will guess where that came from:) ).
Whilst the script works, it is not reliably firing off before JD complains his battery level is low and does his faceplant thing.
Can anyone suggest a better method of achieving an early warning alert?
Thanks.
You can turn this into a c# plugin quite easily
