Touch Path icon Touch Path — Sketch paths with finger or mouse and set turn/move speeds; interactive, educational demo of timing-based, sensorless robot navigation and limits. Try it →
Resolved Resolved by Rich!
Help With An if Script For Motor Control
Help With An If Script For Motor Control
I need a little help with a script. Originally I had a script on the mobile interface where if I pressed a button, the motors would drive forward, and pressed again, the motors would stop. Here's what I had using image buttons...
if (!$pressed)
Set(D1, Off)
Set(D3, Off)
PWM(D0, 70)
PWM(D2, 70)
waitforchange($Direction)
$pressed = 1
ELSE
Set(D1, Off)
Set(D3, Off)
PWM(D0, 0)
PWM(D2, 0)
$pressed = 0
endif
But I have now changed the mobile image buttons to direction button's (along with a custom Movement Panel which is fully scripted with PWM commands) so they can interface with ping sensors, so changed the above script to the following...
if (!$pressed)
Forward()
$pressed = 1
ELSE
Stop()
$pressed = 0
endif
so pressing the button once moves the motors forward, but pressing it again no longer stops the motors. What do I need to change in the second script to get what I'm after?
Thanks.
Just a side note that perhaps I should have mentioned in regards to using "Test", when I run the first script with PWM using "Test", the option to "Stop" the script doesn't show up (which is correct in this example) and the first half of the script executes. When I press "Run" again the second part of the script executes which replaces the first half... and so on.
But doing the same on the second script using Forward() and Stop(), pressing "Run" executes the first half of the script, then "Stop" shows up. And when I press that, the script stops running and says "Done #####". So the second half of the script doesn't seem to be recognised. confused
Looks like YouTube really messed up that video upload. The video still won't play. What was it going to show anyway, as all I'm really asking is what in my script (the second one in post #1) needs changing for it to work the way it should?
If it's going to show how to place a variable as an INIT script in a connection script, I already have that (using $pressed = 0). And as mentioned I am fully aware of what the "Run" function does in a script config menu, and I have been using it for months now.
As mentioned, the first script runs fine and all I've really done is replace the GET() and PWM() codes with FORWARD() and STOP() codes.
Why not simplify it using the $direction variable in ARC?
IF($direction = "stop")
  Forward()
ElseIf($direction = "forward")
  Stop()
Else
  # Robot is turning or moving in reverse. Do nothing?
EndIf
NB. Check the $direction variable exists to begin with. Also double check the directions ARC Movement Panel sets it to.
Thanks Rich.
Sorry for the delayed response as I've only just got around to testing it. Just to note that the $direction variable was already set as I already had it working in the first script (post#1). I had already checked to see if the Movement Panel buttons were scripted and mapped correctly (mentioned in post#1 also), but triple checked it again anyway and everything was as it should have been. I'm curious to why the second script in post#1 didn't work, as its essentually the same as the first one.
Thanks for the advice though, and for your help.:)
