i dont know how to make it work the joystick in c#.is recognized as a device but dont move servos, im used the Example Project is in SDK and i change servoport that im using.
Help please!
Script Collection
— Manage and execute multiple scripts in a single Script Manager using ControlCommand(), with Control Details showing available commands.
Help please!
mmm
I've never really used the EZ-SDK but I figured I'd post the commands to see if you can compare and see if you have any syntax errors:
Field:EZ_B.Joystick.JoystickDevice.ID
Method:EZ_B.Joystick.JoystickDevice.Name
Method:EZ_B.Joystick.JoystickDevice.Axes
Method:EZ_B.Joystick.JoystickDevice.Buttons
Have you tried to move the servos by an alternate method to make your code is working well on that side of things?
You can download the EZ-SDK
Follow the README.TXT on getting it setup correctly
Look at the Tutorial 47 - Joystick project
@ jnicolas , looks like DJ swooped in and saved the day agian
, do you mind marking this thread as answered? Thank you - Josh
