MPU9150 Accelerometer, Gyro, Temperature, Compass icon MPU9150 Accelerometer, Gyro, Temperature, Compass — MPU9150 ARC control reads compass, gyro, accelerometer and temperature via I2C, initializes and sets EZ-Script variables on demand. Try it →
It does help to provide existing code that you have written so we can help build off of it. Could you paste your current code please? Thanks!
All I have so far is adc_wait(adc7,lower,50)
Im not sure how to add an if command say something out ezb speaker.
OK so I tried again.... how do I copy and paste what ive done? My code is this...
IF(ADC7,lower,50) SayEZB " I have detected something in my path " EndIf
It comes up with an error on line 1. Says missing quotes or invalid expression.
                                       Thanks   Chris
Your syntax is incorrect... The code doesn't make sense , but it should run... The if statement is redundant... meaning the if statement isn't needed because the code will continue only if the ADC_Wait returns above 50 ...
ADC_Wait(ADC7, HIGHER, 50)
$x=getadc(adc7)
IF($x>50)
SayEZB (" I have detected something in my path ")
EndIf
This is all you really need....
ADC_Wait(ADC7, HIGHER, 50) #the script stops here until the value exceeds 50
I agree with you to a certain extent... as we move closer to the sensor the number goes down not up. So what I am looking for is when something is detected closer. But I think I can modify what you did as an example. I will try , and then post back. Thanks Richard R
So modify it then...
ADC_Wait(ADC7, Lower, 50) #value lower than 50 or whatever value you want
Sorry Richard R , not working. I need to make sure i'm doing it right though. I just pulled out a script control and scripted inside it.
