Tiny Yolo2 icon Tiny Yolo2 — Real-time TinyYolo object detection for ARC Camera Device: tracks 20 classes, populates camera variables, triggers tracking scripts, 30+ FPS in HD. Try it →
I think the code your using is what i would have done.
Maybe someone has tried this and know if its possible on the mobile view.
Review the tutorial: https://synthiam.com/Tutorials/Lesson/23
Using the "Cheat Sheet" tab when editing a script for the button will show you all of the commands for ControlCommand, and other shortcuts. In this case, your "ShowControl()" will be there for the other control.
@luis Have you downloaded the sample ezb I posted? When you click the button, does it show the other window. It does not show for me. confused
@dj I followed the script as stated. What am I doing wrong? Could someone take a look at what I have written?
The ShowControl() only works on a mobile device. The EZ-Script manual explains..
Quote:
ShowControl( ControlName ) Used for mobile devices and the Interface Builder only, this command will open the specified control into the foreground. Example: ShowControl("Wii Remote")
  1. Edit the script for the button
  2. Press Cheat Sheet
  3. Select from the top of the list "ShowControl()" and find the one with your desired control in it
  4. Click the listing with the desired control
  5. Press the SAVE button to exit the script edit
  6. Press the SAVE button on the button in the mobile editor that you are editing
  7. Load the project on your mobile device
  8. Press the button that you edited the script for
  9. The control that you specified to display will show
When I tested your code . It worked fine for my device.
It is an HP 7" tablet with android on it.
I hope this helps.
Ok. I was trying to test on my laptop. Before I uploaded to the cloud.
Thank You all.
Your most welcome brother .. happy building
